alright dude do that will be easier...
toffy you going round 2 saturday?....
decided on new wheels as well ssr professors now colour thinking chrome or the matt almost same colour as the car
thinking chrome would look good with the chrome seal covers size have no idea
thoughts???
Nah I won't be at round two sadly , I was up there last weekend racing so I'm broke this week , and I'm putting my s14 together . 18" in a 9 and 10 would be my choice , in chrome (I just bought some ssr vienna courage , they would suit this car perfect! )
Edited by toffy
dont support cartel, the owner is a total f**khead.
really better of buying decent when it comes to oil coolers. will have no end of trouble other wise. id also hesitate to put 10's on. you will struggle to find puss enough ones i reckon, unless you got full faggoty toyota specs.
time is coming to throw the ebay turbo in the bin and buy a decent one thinking a garrett 3076r need some advice from others out there on other good turbo ideas????????
Problem with the 3076 and a external gate?
Toffy you'll jizz when you see it for the first time once it's done wish I had turbo and tune for next month for the drift battles :/
As toffy saud kinugawa (sp?) Are decent for the price, theres a hyge thread on them in the forced induction section and alot of people get good power figures out of them at a price a whole lot cheaper than garrett.
Imo the gtx wouldn't really pay off for the extra money you'll pay over a normal 3076, the motors not built is it? so your not going to be runnning huge amounts of boost where youll see the quicker spool times. But thats just going off what ive read on them
yeah ive read abit about them seem good for the price motor is stock internals besides the cams i dont wanna run a heap of boost my goal is to get good power but have the motor safe so it lasts!!
everyone seems to be saying 10 so think ill go with that...
last week or 2 the cars been up in damos shed having wiring done i.e. melted wires fixed horn lights wiring for the manual gearbox and finally found the ems stinger and after a little reading seems like they are a good computer so new turbo and tune needs to come soon!!
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
