should be making over 300 on that boost with that turbo so deffs something wrong there
yeah as i said i have problems with ecu sensors jumping all over the place so it is only a half tune and im not really going for max power
  • 3 weeks later...
need to think/find a new muffler/pipes for the back as the cannon thats on there sucks ass and im thinking twin tip but not sure even another cannon that looks better and sounds better would do please discuss!!!
spent saturday down hobart helping frenchie out with his bus at the round 3 drift day was a good day besides small miss hap that ended the day but the day gave me a boost to do a bit of work on mine today as im still waiting for wiring to get down before it can go back to have the tune finished :down: so just done some fiddly things started fixing a dicky power window and after taking the door trim off found the car had the intrusion bar cut out and a large rhs frame welded in to the door like a heavy duty crash bar or something super strange and have no idea why its been done as the doors have had no repairs or new skin welded to it
other news brought first pair of wheels vskf in 17x9 +18 and have another pair soon 18x9.5 +18
hks oil cooler and oil filter relocation on the way a stainless twin 3inch pipe being made
damo come done last of the wiring on saturday air temp sensor in earth for the ecu fixed power steering fixed heap of wires cleaned up and neatened and is going back in to have the tune finalised this week and some actually good power figures will be up soon the kfs and going in tomorrow to have tyres changed over and try to get them back on and ply with camber and what not to make them fit ready for tune
well not the best news.. after having the wiring issues fixed on the ecu what we thought was a bad earth that was making the sensors (tps,water temp) gitter and making the motor run super rich i then took the laurel back to the tuner (boost automotive) car had to stay there for a day or 2 as he had to tune the cold start and finalise everything else got a text the next morning and was told the car is still not right and is still all over the place as you can imagine i wasn't after stuffing around with the car for so long and and this ecu so that night wiring mate (DJRIFT) went back through the wiring trying to find a bad earth or bad anything started to think as the ems runs off the ome ecu some of the sensors may of been doubled up and that was making things gitter and go all over the place fixed a few wires sent it back there the next morning still no go better but still no go so this weekend we went back over everything with a borrowed laptop to see if we could get it to work we really went through everything tested every wire and every ground nothing we could do seemed to fix the gitter :( we pull the ems out to check the ecu its self we found what may be sign of water damage and to the computer its self so in the end we have out it down to that the ems ecu has shit its self pretty much from water damage or just from age or bad luck and have now been set back more with having to buy a new computer and im not going to put a cheap half ass computer in it im looking at a haltech platinum pro unsure just sad on the hole car at the moment waaaaa :down:
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
