ok so big news laurels tuned and going after a very expensive few weeks ended up throwing out the ems stinger shit edu and got a new haltech platinum pro after having to stuff around with the loom and cas as was all up the shit from the ems (NEVER BUY ONE) got the car to start and the tuner over to load a quick base map in so i could drive it to the dyno the next day few hours later it was done turns out i have a stock fuel pump not a walbro like i thought shame but that held me back on the dyno and tuner had to set the limiter to 6500 as it was starting to lean out over that so ended up with 260kw lot less then i was expecting but will be good to actually get a hang of the car as its still super quick and I've never had anything with that much power before and plan on putting better pump and injectors in it in a few months been going through the hassle of getting it rego passed few hassles but will hopfully have it sorted soon
Was down in Tas for holidays, saw your car (i think) at the bridgestone, looks awesome. Loving the rims on the rear!
Yeah man that would of been mine thanks the wheels on the back I borrowed from a mate had semis on wouldn't believe the amount of grip they give you :)
  • 3 weeks later...
well spent the weekend driving the laurel around regoed and tuned for the first time and had the best time went out with a few friends for a drive friday night car went great beside speedo randomly stopping later find out the cable snapped just after the sender that sucked done few foot on coz straya!!! bit sad on the diff cutting one some times but a locked diff will be going in asap ready for power cruise also had to put a 10mm exstended clutch slave pin in as the clutch wasn't engagging all the way solved that so from now and power cruise actually have to learn to skid the car this will be fun
its not to bad being that there about 3mm gap between guard and tyre in the back I'm running 2 degrees in the back and 3 in the front the back has been lipped only and the front has been lipped and the top rail that always cuts the centre of the tyre in the front I've rolled over flat so it won't cut and also acts as a cover for the wiring loom
na you'll be sweet!
just remember if your gonna go low cut and bash the lip in the front so you don't cut your tyre!! :)
Edited by Samgrainger32
  • 3 weeks later...
cars been going awesome locked diff is in power cruise is entered and can't wait 25th 26th of jan will be the best weekend for this car had a play with my new gopro and suction caps suck keeps going loose and falls down and if got as hero 3 black and after i got home to watch some of the footage it was shit sound was terrible and video was not the best after doing bit more reading i trend the hd down to 720p see how that works anyone else used one and know what settings are best for outside of a car?
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
