ok so big news laurels tuned and going after a very expensive few weeks ended up throwing out the ems stinger shit edu and got a new haltech platinum pro after having to stuff around with the loom and cas as was all up the shit from the ems (NEVER BUY ONE) got the car to start and the tuner over to load a quick base map in so i could drive it to the dyno the next day few hours later it was done turns out i have a stock fuel pump not a walbro like i thought shame but that held me back on the dyno and tuner had to set the limiter to 6500 as it was starting to lean out over that so ended up with 260kw lot less then i was expecting but will be good to actually get a hang of the car as its still super quick and I've never had anything with that much power before and plan on putting better pump and injectors in it in a few months been going through the hassle of getting it rego passed few hassles but will hopfully have it sorted soon
Was down in Tas for holidays, saw your car (i think) at the bridgestone, looks awesome. Loving the rims on the rear!
Yeah man that would of been mine thanks the wheels on the back I borrowed from a mate had semis on wouldn't believe the amount of grip they give you :)
  • 3 weeks later...
well spent the weekend driving the laurel around regoed and tuned for the first time and had the best time went out with a few friends for a drive friday night car went great beside speedo randomly stopping later find out the cable snapped just after the sender that sucked done few foot on coz straya!!! bit sad on the diff cutting one some times but a locked diff will be going in asap ready for power cruise also had to put a 10mm exstended clutch slave pin in as the clutch wasn't engagging all the way solved that so from now and power cruise actually have to learn to skid the car this will be fun
its not to bad being that there about 3mm gap between guard and tyre in the back I'm running 2 degrees in the back and 3 in the front the back has been lipped only and the front has been lipped and the top rail that always cuts the centre of the tyre in the front I've rolled over flat so it won't cut and also acts as a cover for the wiring loom
na you'll be sweet!
just remember if your gonna go low cut and bash the lip in the front so you don't cut your tyre!! :)
Edited by Samgrainger32
  • 3 weeks later...
cars been going awesome locked diff is in power cruise is entered and can't wait 25th 26th of jan will be the best weekend for this car had a play with my new gopro and suction caps suck keeps going loose and falls down and if got as hero 3 black and after i got home to watch some of the footage it was shit sound was terrible and video was not the best after doing bit more reading i trend the hd down to 720p see how that works anyone else used one and know what settings are best for outside of a car?
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
