Just thought i would let everyone know that last night i only got 4 runs because it was busy as.
But I just want everyone know what I got with what mods so that people can see what is possible, because when i first got my car i thought it wouldnt be.
Anyways I'll write down the mods that would have an impact on my time, compared to stock.
500hp Clutch
235/45/17s
Turbosmart Bleed Valve (10psi)
Pod Filter
Iridium IX Plugs (Gap 0.8)
Cat-Back Exhaust (with STOCK cat)
Front/Dump Pipe
With those mods plus some suspension and crap like that i ran a
13.892 @ 102.85mph
60' @ 2.273 (shit time, i can do a 2.11)
so there is a possiblity for a 13.7 if i can do another 2.11 60' time and pull it all together, but my "drag" tyres were running a bit on the bald side.
Just thought i would let everyone know that a 13 is very very possible with light mods.
https://www.sau.com.au/forums/topic/41977-mild-mods-14-mile/
Good stuff.
I ran 13.8's back in the old gtst days with very little done as well. At this time people on the WA forum were telling me I couldn't run a 13.
3 inch Exhaust (standard cat)
10psi bleeder.
Pineapples, they only cost $100 odd and are a 10min job to fit.
I did mine on a 38deg C day though, on 205's with about 100kgs of work stuff in the car
You couldn't have asked for a better night to race in terms of air quality. Very cold and reasonably dry air, excellent for making power.
I think you have further shown how these cars don't like to be 'riced'. Simple little efficiency mods are all you need. Mid 13's are not hard to get either and you certainly don't need a front mounted intercooler. I think the vast majority of the front mounted cooler brigade in R33s with factory turbos are still stuck in 14's, where they belong. :D
https://www.sau.com.au/forums/topic/41977-mild-mods-14-mile/#findComment-859676
thanks rev thought you might be happy with that.....only got 4 runs for the whole night would have liked to have got that 13.7 :P
jolinator: i know they are Bendix Advance and they are the squeekiest brakes ever....also couldnt get those tyres to smoke.... they would just heat up and grip.....awesome tyres tho!! :)
https://www.sau.com.au/forums/topic/41977-mild-mods-14-mile/#findComment-859867
Fane - Don't forget... You had thermal wrap on the intercooler return pipe too :) Big win :) (must do that soon)
Just to give everyone another example that 13's can be had with mild mods....
I did 13.96 @ 101.8mph, 2.265 60' with.....
Xtreme Ceramic clutch (Auto-clutch special :))
235/45/17s
EBC @ 9psi
POD Filter
NGK Copper Plugs @ 0.8
Cat-back exhaust (STOCK 2.25" cat) *cough*
Just a front pipe, Stock Dump.
Oh yeah, Nismo coilover suspension (hard as hell)
At this point the car was running rich as hell, as it had No AFCII at the time...flamethrowing on every gear change *drool*
https://www.sau.com.au/forums/topic/41977-mild-mods-14-mile/#findComment-860716
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
