  • Replies 1.7k
Posted Images
Guys,
Stand up... Place your arms out so you form a cross..... Place one foot on top of the other......
Tell me what is this???????
A shit way to spend easter!
Thank you, I will be playing till wednesday.. Please try the veal.....
Mike
I know it isn't everyones kuppa tea, but it made me laugh and I thought I would share.....
OVERDOSE VICTIMS
These graphic pictures of overdose victims are not for shock value, but
rather in the hope that you will have a frank discussion with friends,
co-workers and family about respecting moderation, under- standing
limits, and knowing when to just walk away.
Remember...
This did NOT have to happen
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
