  • Replies 1.7k
Posted Images
TRADITIONAL CAPITALISM:
You have two sheep.
You sell one and buy a ram.
Your flock multiplies, and the economy grows.
You sell them and retire on the income.
AN AUSTRALIAN CORPORATION: (Workchoices!)
You have two sheep.
You sell one, and force the other to produce the wool of four sheep.
You are surprised when the sheep drops dead.
A FRENCH CORPORATION:
You have two sheep.
You go on strike because you want three sheep.
A JAPANESE CORPORATION:
You have two sheep.
You redesign them so they are one-tenth the size of an ordinary sheep and produce 20 times the wool.
You then create clever sheep cartoon images called Sheepkimon and market them worldwide.
A GERMAN CORPORATION:
You have two sheep.
You reengineer them so they live for 100 years, eat once a month, and shear themselves.
A BRITISH CORPORATION:
You have two sheep.
Both die from foot and mouth.
AN ITALIAN CORPORATION:
You have two sheep, but you don't know where they are.
You break for lunch.
A RUSSIAN CORPORATION:
You have two sheep.
You count them and learn you have five sheep.
You count them again and learn you have 42 sheep.
You count them again and learn you have 12 sheep.
You stop counting sheep and open another bottle of vodka.
A SWISS CORPORATION:
You have 5,000 sheep, none of which belong to you.
You charge others for storing them.
A CHINESE CORPORATION:
You have two sheep.
You have 300 people shearing them.
You claim full employment, high productivity, and arrest the newsman who reported the numbers.
A NEW ZEALAND CORPORATION:
You have two sheep.
That one on the left is kinda cute... :yes:
Subject: Child abuse....
Federal Court Ruling from the Melbourne Age , Australia (AP) - A seven year old boy was at the center of a courtroom drama yesterday when he challenged a court ruling over who should have custody of him.
The boy has a history of being beaten by his parents and the judge initially awarded custody to his aunt, in keeping with the child custody law and regulations requiring that family unity be maintained to the degree possible.
The boy surprised the court when he proclaimed that his aunt beat him more than his parents and he adamantly refused to live with her. When the judge suggested that he live with his grandparents, the boy cried out that they also beat him.
After considering the remainder of the immediate family and learning that domestic violence was apparently a way of life among them, the judge took the unprecedented step of allowing the boy to propose who should have custody of him.
After two recesses to check legal references and confer with child welfare officials, the judge granted temporary custody to the New South Wales State of Origin team, whom the boy firmly believes are not capable of beating anyone.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
