Yeah i dont seem to get them although i thought i set them up to work............ But that is because i am mildly retarded so hopefully this thread points me in the right direction lol
https://www.sau.com.au/forums/topic/419788-notifications/#findComment-6747253
I'm getting them fine.
I suggest you guys check that
1. You've checked the "Follow this topic" button in the top right corner
2. You've set-up your Profile/Settings/Email - correctly. You actually need to go in a tick a couple of boxes (there have been threads on this in the section before).
https://www.sau.com.au/forums/topic/419788-notifications/#findComment-6748269
yep.
lulz thread and whoretown bob.
wont let you follow. when you post it just says saving post. you have to refresh the page.
and wont give you any notifications.
brought this up a few weeks back.
i know its nothing to do with me or any of my 6 computers/devices i use, because other people have the problem and nearly every other thread is fine.
https://www.sau.com.au/forums/topic/419788-notifications/#findComment-6748989
ive just checked it on my work mac. the work pc and my iphail. cant follow it at all!
ive even gone as far as ripping firefox off the computer and re installing it. when adzmax opened the new hometown it worked fine for a few days then the same issues happened again. ill ask them see if anyone else is havin the issues still.
https://www.sau.com.au/forums/topic/419788-notifications/#findComment-6749102
Well I'm using Google Chrome and it's working fine for me.
It's not a special admin access based function - it's the same for all users so there isn't an issue.
Ensure you let the page FULLY load before trying to race through and click the button. If the page hasn't fully loaded it might not load the button correctly.
https://www.sau.com.au/forums/topic/419788-notifications/#findComment-6749117
thanks mate. great help. let the page load.
anyway ive asked the other kids there to jump on here and let you know there issues.
they may be able to word it better. i know its an issue because i get a message on the iphail. ill take a screen shot and post it up.
plus my account is set to automatically follow a thread once i comment. i know this because it does it to every other thread i comment in bar those two.
https://www.sau.com.au/forums/topic/419788-notifications/#findComment-6749130
No need for the sarcasm, we are trying to help you, and cannot find a problem.
If you are going to just dismiss the advice being given, do you really expect us to keep helping?
I've tested with non-admin account, also works fine.
You might have to manually click for that topic only.
https://www.sau.com.au/forums/topic/419788-notifications/#findComment-6749141
forgive the sarcasm. i apologise. but you were rather condescending.
i cant manually click. i try too, it brings up the pop up box etc i press ok but then nothing. the small number next to the follow box is also reading zero. again, over all my computers.... could it be an account problem?
https://www.sau.com.au/forums/topic/419788-notifications/#findComment-6749152
no it loads. finishes loading, then it just goes back to follow this topic with the number 0 next to it.
its not firefox, as i said i can follow loads of other topics and i do. its just a few in the wasteland that it wont let me......
https://www.sau.com.au/forums/topic/419788-notifications/#findComment-6749194
I worded it exactly how i meant it :)
What Antivirus are you using?
Does your Chrome (or Firefox) have any add-ons running in either? If so - have you tried disabling them all and then trying?
Does the actual "pop-up box" appear when you click on the "Follow this topuc" button?
https://www.sau.com.au/forums/topic/419788-notifications/#findComment-6749232
What Antivirus are you using? none (shh) well windows defender.
(nope none what so ever)
post-709-0-17374200-1360719910_thumb.png (yes that pops up. i click follow this topic, the box dissapears i get those little green loading lines on my screen then nothing. i scroll back to top of the page and nothing has changed. it still says follow this topic and the number next to it is zero.)
https://www.sau.com.au/forums/topic/419788-notifications/#findComment-6749237
    • haha don't worry I'm sue you've got more fun ahead buying a 30 year old turbo car....but at least you are in the right place to ask
    • some days eh? The keyless entry and interior light on/off with the key will be controlled by the Body Control Module, but I'm not certain where that is or what it looks like (you might get lucky with a search to get a part#, which could be printed on it). I'd start at the A pillar/ Under dash/kick panel on the driver's side
    • It might be hit and miss, but Nissan Genuine Parts and Pitworks are not the same thing, although both are available from Nissan Dealers with Nissan Part Numbers. Nissan Genuine Parts are the OEM stuff, Pitworks are their attempt to get people back from generic parts makers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
