update?
Also, what type of oil and how much did they use?
Can greatly affect the life of the compressor.
Hi Luke,
After inspection, it looks as though the AC compressor had overheated internally and seized.
The A/C specialist suspected the pressure's were too high due to the older original condensor design as the system was not designed to operate on R134a.
We used PAG46 oil in the new A/C compressor. Between 160-180ml.
Did they replace the reciever drier and clean out all the lines? Cause the metal shavings from the first failure will kill a new compressor very fast
Yes they replaced the reciever drier, cleaned out all the lines, even replaced one. Also did the evaporator, TX valve under the dash. Cleaned the lined out with Shellite. The works.
Hi All,
OK so here is the update and where I am up to.
I have 3x GTR R32 A/C compressors. 2x Zexel (original one off the car that leaked and a second hand working one I bought recently) & 1x Valeo (the new one that failed)
The specialist pulled apart all 3 of them and made 1 really good one. Looks like he decided to use the Zexel housing.
180ml of n8 denso oil has been put in it and we fitted it to the car.
Next we have removed the old condenser from the car, drilled out the rivets and removed the mounting brackets to be reworked into a new universal condenser.
The reason for using a new universal condenser is because it was suggested that the pressures with the original condenser was to high after retro fitting with134a gas.
The old condenser was a 'Serpentine' type and the new I bought is a much more efficient 'parallel flow' condenser.
Just waiting for the rain to clear so that we can fit it to the car, then have to clean all the lines again before recharging the system and it should be ready for winter lol.
Pictures to follow..
Edited by paulyp
  • Like 1
Hmmm.
I have a feeling it may be over oiling.
I have run 134a without any issues.
Even in temps as high as 40°.
Do you know how many mls you put in yours?
Paulyp, did you modify your condenser fan to turn on with the air con?
Hi Dark26, Yes that was modified to turn on whenever the air-con was running.
Will check the fan before re-fitting to make sure its still ok.
cant remember.
Would have been around the 30ml mark.
But, I will check the workshop manual and let you know what Nissan recommend.
  • 4 months later...
Hi all,
Just another update for everyone.
We have finished fitting the AC about 2 months ago and its working well.
Went through alot of effort to fabricate brackets and have hoses made to fit. Also had to modify the standard cooling fan to clear the new condensor.
Please see below pics and it should give anyone thinking of doing the same a good starting point.
Modified GTR R32 Fan
GTR R32 Custom AC Hose Fitted
Modified GTR R32 Hoses
GTR R32 HOSE
  • 5 months later...
for what its worth, if your going to goto the effort of modifying or making up new lines for an ac system, you may aswell replace the compressor with a universal aftermarket type and just get the lines made to suit, and on the topic of higher pressures, you should have a low and high pressure switch installed to make the ac cut off if pressures get to high, yet a newer style of condenser will cool better so lower pressures a bit more and keep the car ac abit cooler.
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
