Less than 3 months old Regu 06&R for sale at $600 pick up. Still have box and original paperwork from Kakimoto. Will post at buyer's expense.
http://www.nengun.com/kakimoto-racing/regu-06-r
https://www.sau.com.au/forums/topic/419922-kakimoto-regu-06r-for-r33-gtr-gtst/
What's the internal diameter in the cannon part ?
Sorry I have no idea. It looks big but I wouldnt be surprised if its not fully hollow because this exhaust is pretty quiet.
  • 2 months later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
