Yellow Jackets Ignitor Modules - S13/s14/180Sx & 300Zx/r32-R33 Gtst - Testers Needed.
Hi Guys,
I am about to release the latest addition to our Yellow Jackets product range:
Ignitor module - S13/S14 SR20DET
Suits:
SILVIA/200SX - PS13/KPS13 - 2.0L - SR20DET (1991-1993)
SILVIA/200SX - S14/CS14 - 2.0L - SR20DET (1993-1999)
180SX - RPS13/KRPS13 - 2.0L - SR20DET - (1991+)
Ignitor module - Z32 300ZX/R32 GTS(T)/R33 GTS(T)
Suits:
300ZX Z32 - 3.0L - VG30DE (01/94-8/96)
300ZX Z32 - 3.0L - VG30DETT (01/94-8/96)
Skyline R32 GTST/4 - 2.0L - RB20DET (05/89-7/93)
Skyline R32 GTS25 - 2.5L - RB25DE (08/91-8/93)
Skyline R33 GTS - 2.5L - RB25DE (08/93-5/95)
Skyline R33 GTST - 2.5L - RB25DET (08/93-5/95)
Maxima from 90-91
Maxima GXE from 92-94
Maxima SE from 92-94
Infinty J30 VG30DE from 93-97
At this point we have carried out tests on equipment with good results but traditionally I like them to be tested in real-life situations before releasing them to the market.
Please PM me if you are interested.
Cheers,
P-W.
I will be interested to help you out, test them fully and post results.
But bear in mind I did have red jackets which lasted 5 dyno pulls before they stuffed. So I hope this is a split fire equivalent rather then different colour same sht.
I will be happy to send them back to you after trailing, but not interested of paying for them.
Are these only suitable for stock/mild power applications?
Curious as to why you have excluded R32/R33 GTRs
These are designed to replace the stock ones that eventually fail and at a cheaper price.
We havent gotten around to doing the R32 GTR ones yet.
Why do you have a car listed (R34 GTT) that doesn't need an ignitor module?
whoops. my bad.
I'm keen to give them a go, what sort of current can they handle? I currently run Bosch mec723 coils on a link ecu. I am running twin r33 igniters in parallel this enables me to run the coils up to full dwell. (About 9 amps). Problem I have is the link has only 3 ignition drives, so it is triggering two coils at a time doubling the current (18amps).
Do you have any higher rated igniters?
Hi,
I did testing for your yellow jacket coils in my r32 a couple of years back. They are still going strong and id like to assist with test for these also.
As before a can provide back to back testing and have easy access to a dyno.
Please let me know,
Looking forward to hearing from you,
Regards,
Ashley Smith
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
