Hey all I recently blew the auto in my r33, stupid me by my stake I bought a re5r01a by mistake (rare 5spd automatic) found in some non turbo r33's and r32's also in v series skylines and v8 infinitys, they are a good box with better gears down low for extra launch, for example the standard 4 speed (re4r01a) gear ratios are on the left and 5 speed on the right
1: 2.785 - 3.857
2: 1.545 - 2.140
3: 1.000 - 1.384
4: 0.694 - 1.000
5: - 0.694
As you can see top gear in each are the same and I'm guess both over drives are the same,
Want it gone as I have no need for it, make an offer! Cheers
https://www.sau.com.au/forums/topic/420282-5-speed-auto-re5r01a-fs/
Haha that sucks! What did you end up putting in?
An Ls1 conversion out of sheer frustration of not being able to find an re5 :P
Edited by Captain Natro
  • 3 months later...
  • 3 years later...
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
