FOR SALE 1987 Nissan Skyline R31 Silhouette – Red
post-78894-0-43604400-1361366835_thumb.jpg post-78894-0-92587000-1361366829_thumb.jpg post-78894-0-49463800-1361366841_thumb.jpg
Very quick car with all modifications engineered.
This is the perfect as a daily drive with the ability take to track days if you’re looking for some fun.
One of very few R31 Skylines’ that have recorded sub 1:10.00 times at Wakefield Park (1:09.80)
6 months rego!
Engine & Exhaust:
310hp on 14 PSI at the wheels
RB25DET Engine (Roughly 90,000kms)
Hi Flowed Steel-Wheeled GCG Turbo (VG30 Rear Housing)
Front Mount Intercooler
Aluminum Radiator
Microtech Engine Management System with Hand Controller
Thermofans with Adjustable Temperature Switch
Blow-off Valve
Stainless Steel Pipe off turbo to Pod Filter
3inch full exhaust system
Suspension, Brakes & Drivetrain:
S13 Front End Conversion
5 Stud Front Hubs
BC Adjustable Coilovers Front & Rear
Adjustable Castor Rods
R32 GTR Brakes Front & Rear
Full Spool Diff
1 Piece Tailshaft
R32 Gearbox
Heavy Duty Exedy Clutch
Exterior:
S3 Front End
Projector Headlights
R31 House – Front Lip Spoiler
Silhouette Rear Wing/Lip
17 x 8” (front) and 17 x 9” (rear) Driftek Wheels in Black
Near new Federal Tyres Front and Rear
Interior:
Great condition considering age of the car
Engine temperature, oil pressure and boost gauges built into center console
Oil Pressure Light on Dash for easy viewing
Front Sport Seats – Semi Bucket Style
Power Mirrors
AND PLENTY MORE!
Looking for $9,000 ONO. Willing to negotiate with a serious buyer within reason.
Will also consider a SWAP so am happy to hear out any proposals.
If you have any questions PM me or contact on my mobile 0423 100 062
Regards,
Nick.
Edited by fabo16
  • 1 month later...
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
