Thanks skyginer.
Looking to paint the car now it's off the road for a bit as the converter ate itself on the weekend so I think I will do a rack and pinion steering conversion e85 and paint job over the next few months.
  • 3 months later...
Gearbox fixed again. New ecu lt16c with flex fuel and dash installed drives and runs smoother than the lt12 that was in it before. Just waiting for a drum of e85 to arrive to finish if the flex tune.
Looks like I might be looking for a bigger turbo now the gearbox is sorted. Lol
I hope it all works for you,
Gearboxes must be getting hard on the pocket and with the extra power comes extra stress on everything.
But it is all part of modifying these things , trying to get it all to work together and hope you have not over done it, haha
Hard not to try and get what you want from your ride without going that little bit further to get it :)
Lucky for me the guys at mv in Adelaide have covered most of the cost under warranty. No chance of being over it yet. If it was easy everyone would be doing it that's what I keep telling myself anyway. Lol
  • 1 month later...
  • 3 weeks later...
  • 4 months later...
  • 9 months later...
Been a while since any updates. Retune with 6boost and new cooler pipes was 350kw on 16psi. Car is apart finishing r31 rack conversion as no one can rebuild the steering box. Also modifying the rear control arm mounts to make them adjustable. Will add photos over the next month.
  • Like 1
  • 1 month later...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
