Hey guys, might be looking at selling my stag soon, im wantng a manual car again :P
Ive noticed my factory exhaust has had a few hits to the ground, and id rather just swap the exhaust for another standard one in good condition rather than trying to repair it.
So ofcourse the exhaust needs to have minimal-no dints and it cant be leaking at all as it will need to pass rwc
Prefer it in West VIC, but let me know what you have, happy to pay for shipping from other states if the price isnt too high
Cheers
Ken
https://www.sau.com.au/forums/topic/420891-wtb-standard-nm35-dump-back-exhaust/
Will be getting my new exhaust sorted soon, so full stock exhaust will be coming off (turbo back). Absolutely no dents, etc. too and no rust :laugh:
In Narre Warren, Vic.
Hey skyguy, im just in need of the whole system except the dump as i have one of scottie's dumps fitted :P
If you dont actually want to sell it in case of defect issues, would you allow me to borrow it when i need it for my rwc? im happy to pay you with a 6 pack or whatever you like :) it'd be pointless me having 2 standard exhausts :P
also sent you a pm scottie!
Cheers
Ken
Beautiful, cheers skyguy!
Scotty is bringing one down tomorrow, if it's no good, ill definitly take you up on your offer :P
Cheers
Ken
  • 4 weeks later...
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
