So I've gotten to the point where I need to do something about the front suspension on my Stagea.
I'm drifting it, and its a 4WD model (run in 2WD) I went for this model as it was the shape I prefered (Series 1) and it seems finding a RWD model isn't easy, we only happened to get them in the S2 model only too due to only being eligible to import the turbo models.
(FYI RWD Stagea shares the Laurel/S15 platform, so it runs mcpherson strut ... oh how I wish I liked the S2 front when I bought my Stag).
Anyway!
I have a few problems, they are:
Driveshafts need to be in place to keep bearings in knuckles
No aftermarket support for suspension arms (knuckles, tie rods, ends etc) and need to modify
Keeps bending tie rods (stock stagea only runs a 8mm thick tie rod, S14 runs 12mm)
No lock gain to be had
and most importatnly, the upper control arm and arm between the UCA and knuckle hits the chassis.
I've been pondering for a week or so now whether to go Mcpherson or RWD (GTS) double wishbone setup. At the moment Mcpherson just seems way too hard to do without pulling out the engine and modding the engine bay (strut towers etc) to do it properly.
My only hope is to convert to the RWD double wishbone setup found in the R33/R34 GTS series.
Benifets of the conversion:
Saves weight, removes the drive shafts
more aftermarket support for arms
can run a moddified knuckle for more lock
But that still leaves me with the arms hitting the chassis.
So after this whole essay about what I've been thinking about, I'm wondering if its possible/safe to cut and shut (shortern) the arm between the upper control arm and the knuckle.
From what I can work out in my head the shorter the arm the move clearance the suspension would have, compared to a car at the same height with a longer arm.
I haven't seen and can't find any aftermarket upright as I'd assume no one has ever needed to mod/change one before.
Then theres the whole problem of the 4WD cradle, using cast LCAs and all that junk. But I've figured out how to combat most of that in my head, I just need to figure out if its safe to modify the upright. I presume it takes quite a bit of load as apposed to a knuckle or what not?
To anyone that says "should buy a RWD model instead" it's not worth doing that now, I've spent way too much coin, effort and time to get my Stagea where it is. Although if I ever stack it, I'll deffinately get a RWD chassis next.
I'm all ears guys, I know there are some extremely knowledgable people on here and would love to here some advice, opions etc.
Edited by Run-It-Hard
I've come up with another idea, which is probably safer. Which is to somehow mount the knuckle above the arm rather than below. Though that might pose a change in geometery and how the upright works etc. probably be a mission and hit the arm etc.
  • 1 year later...
Hey Adam,
I’ve read Part III of “The Quest For More”, did you end up getting it all installed in the car with more lock? I’ve just started taking my S1 to the track and looking for more lock, so far it’s pretty standard in the front end apart from coilovers. I’ve seen a kit for the 32/33 from Garage 7 that looks alright but would prefer to swap spindles before installing one of these kits (http://www.garage7.com.au/home/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=2952&category_id=616&option=com_virtuemart&Itemid=53 )
Regards,
Kierin
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
