Thanks mate. Doe that mean that the car comes with a rev limiter? I haven't dared to rev to the red line so far since I'm not sure if there is one. Last thing I want is to blow the engine within the first week of getting it :)
@2500 rpm the boost kicks in, @3200rpm full boost hits, the rev limiter is set to 6900rpm from memory, or 7000rpm.
max torque should be at 5500 rpm and max power at 6700rpm.
thats what i think it said in one of the service manuals
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
