There are 3 people running this setup.
Me
Eat26
And a white 33 gtr on this forum.
They are the perfect size in my opinion. There is no need to roll guards, but my splash tray does scrub on full look.
You running 265 or 275s
Any stretch if using 265s
Going to get these for track wheels ;)
Nice one mate, exactly what info I need. I don't have a splash tray on my car so should be fine. I am running 265/35's.
Can't think of any other wheel that will suit my skyline better, I have a Le Mans edition R33, hoping silver RPF1s look spot on.
Got any links to your car mate?
Me
Eat26
Edited by ab20000
I think black RPF1's would look tits against the blue
I have a second set for the track also with 265/35/18s and they're not stretched at all, the tread width of Semis seems to be wider than road tyres for some reason.
They fit beautifully. The street spec Toyo T1Rs do look a tad stretched though, but not enough to bother me.
Gorgeous wheel if I do say so myself, that's why I bought two sets.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
