  • Replies 42
ATM the exhaust is just cat back how big would you go the whole way through?
What's the diametre size of your car back?
If it's a 3", then go 3", if it's a 3.5" go 3.5" etc...
​Keep it consistent.
What N1 turbos you getting?
From memory they came from factory running about 1 Bar = 14.7 Psi.
(R32 GTR Nismo & N1 / R33 GTR N1 / R34 GTR V-Spec N1 & V-Spec II N1 / V-Spec II Nur / M-Spec Nur)
You could run a tad higher 1.1 Bar = 15.9 Psi / 1.2 Bar = 17.4 Psi.
What do you recommend? I'm open minded. Honestly, I was thinkin of purchasing the Garrett equivalents as I official N1 turbos would be pricey.
I thought these cars needed a little back flow. Having the whole exhaust the same size would not promote that.
Yes, genuine N1 turbos would be pricey at the same time rare to find.
Garrett -7's would be the closest to the N1 equivalents.
I am running Garrett -7's with 15.5 Psi, which is just over 1 Bar.
Later I will run about 18 Psi = 1.2 Bar, but will get my mechanic to see what he thinks best.
Many factors are involved but you'd run what's safe for the engine / what the turbos can handle, so when you go in for a tune after the twin turbo installation, your mechanic should be able to gauge what it can run.
Not that I know of... That theory might apply to N/A cars... As you can only go so big unless it's tuned for it...
With turbocharged cars, usually the bigger the better, but 3" / 3.5" is usually the upgrade we all go for and it frees up the exhaust flow.
​Just in regards to your bigger front mount intercooler, you were better off spending the money on Down and Front Pipes with a High Flow Cat.
Giving your GTR a full exhaust upgrade will benefit you more at this stage, if you just want to keep it stock-ish...
Stock GTR front mount intercooler can handle 300+ kW's.
But anyway, all for the better in the long run.
I know it'll do 400+ kW's for a fact as well ;)
I apolagize it has a 3.5 inch all the way through just had a look before with that and a bigger intercooler does that add any more hp with out a tune? Just curious cause next step is a bigger fuel pump, injectors, tune and ecu yeah?
:laugh: yes clearly, you would know!
Good and thanks for clarifying that!
So your exhaust is all good then!
Depends on what power out put you want... How many kW's you want?
Which determine if you need a bigger fuel pump / injectors / ECU / Tune or not...
I'm looking for 350 hp at the wheels..... So im guessing I need a fair bit
Which is about 261 rwkW's.
You stock injectors / fuel pump / ECU can handle it.
The ECU will need a slight tweak but nothing crazy.
What ecu were you running?
Run a Nistune or an APex'i Power FC.
Id say that you will very quickly get bored of 250kw. So i would recommend a link ecu. I shouldve skipped the power fc stage and gone straight to a link
What link will you reccommend? Shouldn't get bored to quick as I'm only used to driving a vz sv6 haha
What's the highest stock whp that can be SAFELY achieved using stock components and N1 turbos?
Sent from my SC-03D
Sent from my SC-03D
To be safe for street use, anywhere around the 300kW mark at the rear wheels.
Two friends of mine on SAU are running stock RB26's but one has Garrett -7's and the other has Garrett -9's
Both making 300rwkW's, which is about 402HP at the wheels, if you want to measure in HP.
You could push it further but it will depend on the condition of the engine.
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
