I just got one of these second hand http://www.prostreetonline.com/pso/pages/d...sku=E01-GRDY-01 for $580, its aparently 7 months old. the display is in good condition the controler is a little worn. anyway my question is where can i get this thing installed for a reasonable fee, somewhere close to claremont.
thanks
https://www.sau.com.au/forums/topic/42181-ebc-installation/
ahh hey mate :(
yeah I got it sorted, although i had a loook at it that night and two nuts where missing and one was lose so i had to take it back to get it fixed up... pretty annoying but all good in the end, and a decent price.
I just need to get this boost controler in and looking good.. and my car is sorted till i find some mags.
https://www.sau.com.au/forums/topic/42181-ebc-installation/#findComment-863165
ok so i pay 200 to get it installed and i go to pick it up.. and the ygo well its installed and everything is fine except for the fact you cant even get into the boost menu.... ERRRRRRRRRRR anyone heard of this before? have I been sold a broken bc? I have the guys number who sold it to me so ill see what he has to say. is it possible to reinstall teh software on the sd card?
any comments would help cheers
https://www.sau.com.au/forums/topic/42181-ebc-installation/#findComment-865640
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
