Hi guys, thought id put together a bit of a build diary to keep track of the build. its something i didn't do with my other cars and i regret it now as i have no pics or a log of how they come together.
On that note, just a bit of my car history.
my first build was a 1989 nissan S13 silvia. the car started out life as a completely standard down to the factory wheels and airbox ca18det auto. by the time i come to sell it, it was rb25det powered, garrett gt3076r, externally gated, sub zero plenum, and all the other usual bolt ons making 277rwkw.
next was a 2006 bionic blue xr6 turbo ute. again it went from a stock vehicle to 382rwkw wearing a host of process west gear, external gate and so on.
during my time owning the ute i also had the dis-pleasure of owning a 1993 r32 gtr. unfortunately when i purchased the car it was to far gone to be recovered and i sold it at a loss.
somewhere amongst those cars i also owned another sr20det silvia and a d40 navara work car.
this brings me to now, and as of late 2012 i become the owner of a 2000 R34 GTR V-Spec.
this is me picking up the car, such a happy day
when i got back home i threw it on a local dyno to check it all out
couple of shots from a bit of a photo shoot
and now the fun starts
Adam
https://www.sau.com.au/forums/topic/421911-r34-gtr-v-spec-build/
So to add to the already fitted vi-pec ecu, mac valve boost controller, twin 3 to 3.5" exhaust, turbosmart fuel reg and tuned by godzilla motorsport...
Garrett -5 turbos
Hpi 3" dump pipes
I also grabbed a set of manifolds that are now in the more than capable hands of pro fabrication getting ported
Edited by drag-on silvia
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
