So Guys,
I am wanting to know hopefully without a debate through peoples knowledge if it is ok to register a R32 Skyline with a RB25 in it.
Knowing that a R32 Came out with a RB20 and RB26 and you are technically allowed 25% change in engine size which the RB25 fits either side of the RB25 and RB26.
As the RB25 is a great upgrade for a R32 I am trying to figure out if registering it with the RB25 will cause me too many issues like getting it engineered compared to keeping it as a RB20.
Thanks for you input.
https://www.sau.com.au/forums/topic/421915-r32-with-rb25/
did you have to take it through dickson though...... in this case I am only needing a regular inspection, but seeming that the R32 came out with a 2.6L as well all the other engines.
Its such a tricky subject I have spoken to RTA and they said it is fine but you never know with them clowns
https://www.sau.com.au/forums/topic/421915-r32-with-rb25/#findComment-6788148
You never know, some people have horrible experiences at dickson, some don't I took my 32 over dickson to get rego from nsw to act. They passed it, after I put a rego muffler on. I was defected years later for too loud an exhaust, took it over dickson again, they found that my coilovers were leaking, but didn't say boo about the engine, mind you it's an r32 rb25de thats been turboed.
So it's really luck of the draw I think. You might be okay, or they may decide to pick over every little thing.
https://www.sau.com.au/forums/topic/421915-r32-with-rb25/#findComment-6788158
In my case mine wont go through dickson as it has a high mount, fmic, exhaust etc so i would get it all done through a regular inspector that wont crack it at the high mount etc.
The only issue i have is the rb25 issue but by the sounds of what i have heard, research etc it is ok.
https://www.sau.com.au/forums/topic/421915-r32-with-rb25/#findComment-6788160
Where did you see this?
As far as I was aware, any modification from factory requires certification.
Some people on this forum have convinced the person doing the inspection that RB25det does not require certification in a R32 because, as Chris mentioned, it an RB25 was a factory option at the very end without being specific.
I'm pretty sure the RTA that being referred to is Rego ACT/TAMS(???). There isn't a Australia wide department, unless you were thinking about The Department of Infrastructure and Transport. They provide a set of standards and guildlines for states and territories, it isn't supposed to be the hard line at the moment.
https://www.sau.com.au/forums/topic/421915-r32-with-rb25/#findComment-6788275
I thought it was %15
And that was 20 years ago, if they changed it, it would be even less or nothing by now.
lewis in SA make a 2.25l which is %12.5 bigger, still under the %15.
I had a 1600 celica with a 2l but it still said 1600 on the block. how?, 1800 crank and rods with a 3.5mm overbore, and a Yamaha twincam head.
Careful, as the 32 with a 25 was non turbo, and the 26 was a GTR with different brakes etc.
You may have to be real sneaky, but if you get it on paper... sweet.
Edited by D.I.Y. Mik
https://www.sau.com.au/forums/topic/421915-r32-with-rb25/#findComment-6788280
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
