Hey guys. I wanna dump my R32 on its nuts. I have the options of a few springs, and out of the following which would be the lowest...
  • Kings Super Low
  • TIEN
  • Whiteline
Can anyone recommend any springs if the above arent much good? I had H&Rs in my old ride, nice spring, not very low but. I am going to change the shocks sometime before xmas as well. (car is still on a boat).
Thanks guys
https://www.sau.com.au/forums/topic/42192-r32-gts-t-how-low-can-you-go/
Shoot, why not save yourself some money and just leave the springs out all together. Sit it on the bump stops, it will be low then. Won't go round corners or accelerated due to lack of traction, loose about 8 rwkw through excessive driveshaft angles, won't stop, chassis will crack around the suspension mounts, can't listen to tunes 'cause the CD will skip all the time and there is plenty of proof that says "low is slow" etc.
But hey, it'll look good.
Seriously, take a look here, there are plenty of tips on what to do with skyline suspension including recommended heights;
www.whiteline.com.au
We run our 335mm - 345mm, DMS std is 330, Tein is 320... What he said!
TT
So apart form the stupidity of the first post. What experience has everyone had regarding their springs? Im looking at the Tien S-Tech springs.
..if your car doesn't turn up with adjustable coil overs. The springs will be about 7kg front and 5kg rear - (Normal Jap AM) So just wind it down to suit. Because of the ratio 1mm on the shock is about 1.5 on the car
TT
Have a read of this thread, it is full of peoples experiences with different brands of springs and shocks
http://www.skylinesaustralia.com/forums/sh...ead.php?t=38315
As TT said it is pretty rare to see an R32 come in with standard suspesnion on it, it may pay to wait until you know what you have got before you buy anything. Research is good though.
can't recommend any springs sorry, i think kings super lows are pretty low but don't know if you can get the tyres sitting up in the guards. here are some pics though of a mates 32 on its sack. has height adj coilovers... Rb20_4valve on these forums.
http://teamintegrated.org/cars/japspec/ima...ges/image17.htm
http://www.pbase.com/image/15147520
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
