Hey everyone I bought a skyline r33 gtst 1996. So the guy told me it had a r34 turbo a front mount and an exhaust I told my mate to have a look at it and he said its also got a Mitsubishi bov. Do I get an after market bov or a stock one ? And also who do I take the car to, to get the boost up to at least 10psi ??
https://www.sau.com.au/forums/topic/422114-new-guy-with-a-skyline-r33-gtst/
on a stock ECU, yes - you get breakups after 11 or so and a massive rich-and-retard in the middle (i know alllllll about this one :( )
even with aftermarket ECU, try to stay at 13 or under - reliability and all that, the turbo's almost 20 years old if still stock.
Hmm - you can probably run 12psi then, but yeah, with stock ecu you'll get massive rich-and-retard in the middle (like it has MASSIVE lag in the middle of the RPM curve), then comes on ridiculously strong. If you're not used to it, you'll punch your car into a pole.
If you haven't had a turbo car before, set it to 9psi, have a play with that, and then once you're confident (and I'm still assuming no funny business on the roads), then look at moving it upwards.
When I first got my 33, mine was set to 12psi and it scared the living shit out of me. (admittedly with a Power FC so the midrange grunt was back)
Lol umm well I'm kinda getting used to it that's why I've been asking just started a little funny business on the road and haven't had problems. Maybe I should leave it at 10psi and see what happens from there.
There is no way of saying what boost to set the car to to avoid R&R. Mine used to R&R at 8PSi. Why? Because I had an efficient intake and exhaust.
The ECU goes spastic at a certain AFM voltage depending on RPM. AFM voltage is all about air flow, (Cubic feet per minute for example of air flow). Boost pressure is all about a restriction.
Restrict the exhaust, and then at the same boost pressure you'll make less power. Why? Less Cubic Feet Per Minute of air flow.
For the sake of your turbo, set the boost below 10PSi.
For performance sake. Set the boost on a dyno, and still keep it below 10PSi.
Haha I don't think I'm ready for track still getting the hang of it.
I had my mate drive it and he showed me its full potential so when I learn to drive like him then ill take it out on track.
The track is the best place to learn how to drive it, and it's the only place you want to drive it hard.
Take it out to a Texikhana too, very good for learning your driving skills.
Yep, definitely Texi - helps you learn heaps more about how the car handles and reacts - nice and cheap too!
The next step from there's doing a Marulan Driver Training Centre day, awesome fun. You go in the learner group, and take your time. Did that last time and learned heaps about how the car flows on the track, first time out on a real track.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
