SERIES 1 PARTS
I have a couple of rb25det motors and a complete manual conversion for anyone that is interested
All my aftermarket parts are listed separately
r33 gtst rear 5 stud conversion
hubs
rotors
calipers etc
$220
R33 complete boot trim
$70
r33 gtst front hubs,slotted vented rotors and brakes good for 5 stud
$220
r33 gtst drive shafts
great condition
$30ea
Rear reo
$40
r33 rear cradle just the cradle
$20
Radiator support great condition
$50
r33 gtst brake master complete non abs
great condition
$30
r33 engine crossmember perfect for rb conversions
$50
R33 power steer rack
Great condition
$30
r33 front sway bar
$20
R33 series 1 engine loom
Good condition
$150
R33 series 1 ecu
$70
R33 gtst gearbox $1150
r33 series 1 behind the dash aircon stuff
make a offer
r33 series 1 window trims from door and car the one that always fade
make a offer
r33 overflow bottle
$10
R33 gtst ignition barrel and locks with key
Good condition
$130
R33 gtst side mirrors
$20 each
R33 s1 drivers window switch
Good condition
$70
r33 passenger side gaurd with blinker
maroon and white
$20
R33 drivers side Gaurd with blinker
White
$20
R33 series 1 bonnet
White and gunmetal grey
$120
Series 1 front reo
$60
R33 headlight passenger s1
Chrome backing
Broken mounts still works tho
$60
R33 headlight drivers s1
Black backing
Broken mount still wrk fine
$60
R33 s1.5 front bar
White could do with coat of paint
$130
R33 series 1 dash
$30
R33 series 1 a
Manual diff 4.11
$140
R33 gtst centre console
Good condition
$20
R33 series 1 radiator
$50
R33 doors bare
good condition
$20 each
R33 gtst tail lights
Great condition
$20 each
R33 glovebox
$20
R33 boot with aftermarket wing/spoiler looks similiar to standard one lights up skyline
$20
R33 boot with Gtr copy wing
White
$100
R33 handbrake with full handbrake cable to hubs
$30
R33 passenger window reg motor
$35
R33 drivers window reg and motor
$40
R33 passenger window switch
$20
R33 bonnet latch and cable
$30
R33 bonnet latch bracket
$20
r33 boot and fuel flap latch assembly
$20
r33 air con unit/display
$20
R33 rear bar maroon, silver and white
$30
R33 complete air con set up with everything!
condenser
compressor
dryer
lines etc
$130
R33 rear seats
$30
SERIES 2 PARTS
R33 series 2 dash complete in good condition
$80
R33 series 2 manual diff
$140
R33 genuine gtr grill
White bit rough needs to be fixed up
$40
R33 series 2 headlight
One broken clip for grill
$70
Bare rear subframe
$20
rb25det series 2 afm pink label great upgrade for rb26 I have 2
$60 or $80 for both
R33 manual cluster series 2
$70
hubs
rotors
calipers etc
$220
r33 gtst front hubs, rotors and calipers
$220
r33 series 2 gtst drive shafts
great condition
$35
r33 gtst series 2 brake master complete abs
great condition
$50
R33 gtst gearbox
$1150
R33 clutch master cylinder
$60
$50
R33 series 2 power steer rack
Great condition
$30
R33 aftermarket front strut brace
$40
r33 front sway bar
$20
r33 series 2 behind the dash aircon stuff
make a offer
r33 series 2 window trims from door and car the one that always fade
make a 0ffer
r33 overflow bottle
$15
R33 washer bottle
$30
R33 standard shocks and springs
$40
r33 gtst series 2 front seats
Great condition drivers have minor tear
$50
r33 series 2 rear bar silver
$40
R33 gtst series 2 ignition barrel and locks with key
Good condition
$130
R33 gtst series 2 side mirror passenger silver
$30
Silver
$30
R33 gtst series 2 centre console
Good condition
$20
R33 series 2 door passenger
good condition
$20
Great condition
$30 each
R33 glovebox
$20
$50
R33 pasenger window reg motor
$35
R33 drivers side window reg and motor
$40
$20
$50
$40
$30
r33 series 2 air con unit/display
$30
R33 series 2 steering wheel with air bag
Make a offer
R33 series 2 complete air con set up with everything!
$150
i have all the interior plastics etc
So much more just can't think text me or pm me if you need anything
Gold Coast can post
0487924497
https://www.sau.com.au/forums/topic/422588-wrecking-r33-gtst-manual/
Hey bud
What do you mean by rear and front reo?
Reinforcement bar?
Because I need a front reinforcement bar that sits behind the front bumper that prevents front end crush etc.. But I'm sure you know about that anyway, did you have one of those?
hey mate was just wondering if you have a rb25det engine thats running. i got a blown my 33 up and need to get it back on the road asap. im located in Victoria
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
