  • Replies 122
Yep BYO Richard, Bottle'o across the road.
Sweet!!
Nick, you aren't able to give me a lift from chatswood by any chance are you? :D
There'll be a number of ales in it for you :D
Richard
Well I'm going to be about 15 mins to 30 mins late as I have convinced the better half to come out for a meal! So that is now 2 for me!
Now the drama is, bring the skyzer and I have to drive or bring the pulsar and try and convince the better half to drive!
Skyzer has the advantage atm!
Really Dan!, the skyline, i need to rekindle my love for the drift beast that is your car, hehehe.
anyways i'll just be over here.............
Sorry guys....work has pulled a fast one on me and I have to work tonight. Bugger....still keen on joining up though. Will send my application through snail mail. Hope you have a good time and will have to catch up at the next track day or something.
Oh my, looks like you will learn the hard way tonight :rolleyes:
We are regulars at this particular restaurant, might have to have a word to our friendly chef and inform him of your violent and cheeky tendancies.
If I were you, id be bringing a raincoat :P
If I were you, id br bringing a raincoat :rolleyes:
Finally some payback!! :P
Big thanks for the lift too champ :rolleyes:
Richard
LOL... ok, I'll bring the skyzer and drink lights... just as long as you promis to react the same as you did through turn two the first time that day!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
