For sale is an incomplete project that needs a bit more work to get it on the road. It as a fully working rb30det conversion with rb25de head fully reconditioned with 100lb valve springs. It also has the following,
Fully recoed r32 gtr gearbox
Npc organic heavy duty clutch
New genuine front and rear main seals
Drilled out sump return holes
New CV boots all round
New 52mm rad
Nitto oil pump
Tomei 1.1 oil restrictors
Arp rod, mains and head studs ALL L-19!
SPOOL rods
CP pistons
New timing belt locator holes
New tensioner pulley
New idler pulley
Rebuild starter motor
60mm genuine tial wastegate
T04e t4 top mount turbo
Nismo engine mounts.
New Welsh plugs
New water pump
New JJR interior kit.
Side intake plenty with velocity stacks
New aac valve
New cold start control valve
R32 gtr injectors fully cleaned
Bosch FPR.
BOSCH 040 fuel pump.
New fuel lines
New front brake lines
Fresh rebuilt brake booster
New BM57 brake master cylinder
S14 stubby clutch reservoir
Braided clutch line
Apexi avcr
4wd kill switch
New genuine cam seals
Genuine rb26 head gasket
Mod plated for turbo kit, bigger engine and modified front reo bar
Clear front side indicators
Genuine steering wheel just put back on, needs to be recovered though.
New genuine coil pack loom
New yellow jacket coil packs
Fully balanced engine!
Sorry stuff is all over the shop just trying to remember some things.
Now SOME of the stuff I have receipts for. Due to the qld floods we have had I lost a lot of paper work
it also has nistune ecu which still needs to be tuned
It also needs the dump pipe and wastegate pipe finished plus a few other little things for rwc.
Will post up pics soon
Looking for $25000 ono
https://www.sau.com.au/forums/topic/423001-r32-gts4-4-door-rb30-awd/
You may want to consider parting out or revising your price if you are serious about selling this, as you are asking tidy gtr money for an incomplete gts4.
In all honesty I don't know how you would go getting this money for a complete car, but it's hard to say without any pics
Sounds really cool, but ^ he is right. Parting it out if you have the time would be the best way to get back some $$. For comparisons sake, there is an R32 with fresh respray, rb30det (300+kw), immac interior, complete ready to drive for $13k on these forums.
Best of luck though, sounds like you've put a lot of time, effort and $ into it so far....shame these cars aren't worth all that much any more....
Yeah true. But 4 door gts4 are becoming rare and so ask a good price. I talked to one import car sales guy in SEQ who's quite well known and he reckons in the right circumstances there's no reason I wouldn't get 30 k for it. I honestly thought the guy was on drugs and a couple of other import car sales people also told me 28 and 27! Due to the fact there is no redbook price for these apparently.
I would be happy with 2004 mkll xr8 manual or 2002 sti. I read the post and I can appreciate where you guys are coming from. But I guess my centimental attachment to it from all my hard work maybe blinding me from the truth of the price. Has taken 2 years of consisting working on it myself to get it there almost nothing has been out sourced other then machning and parts.
^^ call what you want. I have 24k. Thanks very much. The vehicle has been advertised elsewhere for a while and has had several parties interested in it. Maybe next time you should consider a big view of a picture bar what flickers of sight you see...
I just think you are full of shit. This may have been advertised elsewhere, and you may have taken picutres that I wanted to view but could not sight as they were unseen, but from what I read, the engine ran like crap last month, the parts list is not all that impressive, nobody was intersted in buying your engine, you don't provide a phone number in your sale threads so I doubt your seriousness and finally I have my doubts in anybody with any sense having purchased this home built beast for 24k. 7-8k, maybe, but not 24k.
Lol don't need to supply number unless its necessary from a pm and yeah it was running like crap thanks to a warped brand new manifold leaking air, but luckily for me the supplier gave me a brand new one that wasn't, runs like a charm. And secondly did I come to your threads bashing on yous? No so f**k of you rude dream boats jam your heads back up your arses and please keep talking shit elsewhere. The person who bought the car has seen EVERYTHING that has been done and knows the car was done miticuosly. Next time ill come picking on your threads and bashing. If your so f**king bored in life and you get your kicks out of giving shit to people you need a f**king drop kick in the head or your just a pathetic f**k with no life either way f**k off.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
