Found that my check engine light will come on sometimes after prolonged periods of high revs (when drifting at track or last night for a short moment on a mountain drive).
When the light comes on I can't hear knock and the car does not run any differently. I also found that if I touch the accelerator pedal the light will go away straight away. After a drifting run the light is on if I let the revs drop down slowly the check engine light will disappear without me doing anything once the revs get below around 2500-3000.
It seems like a very strange problem and am just worried about causing damage to the engine more than anything.
I have:
Rb25det Neo
Full exhaust
Splitfire coilpacks
ARC FMIC
Nistune
also have but already noticed this problem before installing/tuning for:
z32 AFM
ATR43 G2.5
Bosch 023
Would the check engine light come on if there was a fault with the O2 sensor? Main reason I ask this is a long time ago the plug to my O2 sensor was badly melted yet it all seemed to work fine so I tucked it away from the exhaust so it wouldn't melt further and haven't really had any problems to indicate it isn't working under normal circumstances (I get normal economy for a r34)
https://www.sau.com.au/forums/topic/423037-r34-check-engine-light/
i would put my money on that the o2 sensor is playing up / overheating
had the same issue with my R34, whenever i would take it for a spirited drive or a power run on a motorway i would get the engine malfunction light - replaced the o2 sensor, cleared the ECU, never had the error light come back since
would go with a genuine Nissan item which is available at kudos motorsports;
http://www.kudosmotorsports.com/catalog/nissan-lambda-oxygen-sensor-genuine-nissan-skyline-r34-25gt-25gt4-25gtt-rb25de-rb25det-neo-p-187.html
Will give a new one a go I have a good idea that it is 90% likely the issue is from the O2 sensor and nothing else. Unfortunate the error code doesn't remain long enough for me to check it without a laptop plugged in like GTSboy recommends
I'm surprised no one has told you this already. Basically the 2 common ways are u can use a Nissan consult cable and hook it up to a laptop with the right program, or you can get the car to go into self diagnostic mode and spit out the code via flashing lights
I would have lent you my consult but Im in syd.
But the second flashign light method method is just as easy
Search for the Service manual online, or have a look at this thread.
http://www.skylinesaustralia.com/forums/topic/266512-reading-nissan-fault-codes-ecu-fault-codes-how-read-them
That should be enough.
Edited by sonicz
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
