Possibly silly question
Do you guys lubricate the plastic check straps on your doors? Mine are dry as right now but work fine and hold the doors nicely. So I'm wondering if the plastic ones should stay this way and may become too loose with lube? Can't seem to find any good info online
All my other cars had the metal straps that normally need the odd swipe of grease to stop rusting and becoming noisy and clunky
https://www.sau.com.au/forums/topic/423177-door-check-strap-lubrication/
