SO over the weekend me and a mate upgraded the turbo on my RB20 to either an RB25 neo turbo or a VG30 (unsure what i ended up with. says OP6 on the rear housing)
anyway...
we replaced the turbo with the above
the stock front pipe with a 3" one
and the decat with a catco highflow cat.
drives fine, only running R33 waste gate actuator pressure (5.5psi or whatever).
before changing the turbo over i had a decent spool/induction noise.
now it sounds like a stock MK5 golf turbo. very quiet, high pitch whine. so what happened?
https://www.sau.com.au/forums/topic/423295-where-has-my-spool-sound-gone/
No shaft speed = no spool up sound. The old RB20 turbo was running 10 psi and so was spinning harder. That sound is the sound of sharp alloy edges beating the crap out of air. Bigger compressor turning slower = less beating.
Boost it up and tune it and you'll be back to where you started (sonically) and about 30rwkW happier. Don't do this unless you have a good fuel pump etc etc etc. Wouldn't want you to destroy it.
Hmmm see I thought that might be the case.
But even when the guage reads say 2-3psi on the old turbo there was sound.
Guess it could just be down to the turbo having a different sound.
Will have to just wait till I get a tune. Not keen on just winding up the boost. All supporting mods are there fmic fuel pump etc. but yeah
Edited by CRSKmD
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
