Hi all, For sale is my V35 sedan, Details are as follows, This is a Genuine sale, I have a new car.
Asking price is $16,000 but I am open to negotiation.
I am the 1st Aus owner, Low Km's, Tasteful Mods, Regular services, mature owner.
Roadworthy is done, QLD Rego till September - She is ready to go!! :)
This car is reliable and such a pleasure to drive, plenty of power and handles lovely with the Tein suspension and slotted front rotors. The Agency power exhaust has an amazing note whilst not attracting unwanted attention. Driving at night is a dream with the projector headlights and 50W Hid's with secondary 35W Hid's and Angel eyes.
Original exhaust and suspension can be supplied if required.
Mods:
3” stainless exhaust Y-pipe back
MACE 8mm Plenum spacer (First one in Aus)
NGK platinum plugs
K&N Panel filter
350z intake pipe
Alpine Mp3/ipod Head unit
Focal splits
Type S 12" in fibreglass molded box
Custom projector headlights FX-R 2.0
Stillen Engine damper
Strut brace
Tein Control master coilovers
Dark tint
Carbon fibre look engine cover
Features:
6 speed manual
3.5litre
Battery year old
18” mags
A/C, Pwr Steer/PWR windows/VDC/ABS
Aus standards immobiliser
Paint in good condition (few marks)
700kms per tank
No oil/ coolant leaks
No running problems
No interior damage/rips/scratches
New windscreen
****PERSONALISED NUMBER PLATES DO NOT COME WITH THIS SALE*** Standard issue plates are attached to this vehicle already
Car is located in Brisbane Bayside can be viewed on weekends or by appointment. Call Samantha, anytime on 0402699119 or email [email protected] Thanks for looking.
https://www.sau.com.au/forums/topic/423424-2004-v35-sedan-manual/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
