That's what I thought Terry, I've seen them advertised elsewhere, for double the asking price. Anthony did say he sent them an email, but i'm not sure how he got on.
I quick search yielded this image on Google, is this the jacking point you were referring to?
Edited by White GTS-T
ive sent them 2 emails but no reply :(
by the way how do you jack up from the diff with a diffuser? should there be a hole?
Usual V-Spec rear diffusers have a central hole where an aluminium nodule pokes through. This bulbous protrusion is held on by 3 rivets and a bracket. Bodyformaero aka Peter made one for my first R34 GTR diffuser.
In the above pic, I can't see it, so jacking might have to be done via an arm; or remove the diffuser initially.
just called them and they still have it which is good, they dont reply to my emails though lol, il PM terry and see what he was saying aboutbthe jacking point thing
Just buy one from Nissan...
The knock off diffusers don't have the jacking point either but I just bought one from Nissan
The Diffuser I bought
The Jacking Plate from Nissan
Noy
The diffuser was $1500 landed airfreight into Brissy.
The jack plate was about $200 landed from Jesse Streeter.
I'm doing extensive mods to the back of it and custom diffuser fins etc so didn't wanna hack up a genuine one..
Sure you can get a second hand genuine one for the same price but I couldn't be stuffed waiting for one to come up.
I like the idea of using the jack just like the OEM one does..
Noy
Congrats on getting your complete item.
For anyone else who might be after the triangular jacking plate, Peter at Bodyformaero has the template to make one up. :)
cheers Terry im wrapped :D
hopefully comes in one piece yayyyy finally. its taken 2 years to find one
