i dont wanna take over this thread but i have walbro in tank on standar wire and plug - pumps to surge tank then two 044 to fuel rail - i then have two relays one for each pump generally is fine but twice now the wire has burnt out directly at the battery terminal - fuses in the relay dont blow just cuts out coz there is no power and i turn car off straight away..
why is this happening
should i be wiring my direct power line to another wire and not the battery?
dont wanna take over so if something knows pls pm me
  • Replies 48
Poor wiring, wrong choice of fuses and/or fake pumps draining excessive power.
If your fuses are not popping and your wires are melting, I would be VERY concerned at whoever wired your pumps & relays up.
Usually those automotive relays handle up to 40A max, these pumps at full song should only draw 14A give or take 1A depending on temperature (adds to resistance and current draw)
So you should be running only 20A fuses per relay circuit per pump, or a combined 40A fuse for 1x relay for 2x pumps.
You could get away with 15A fuse, but incase of start up current draw spiking I would just add a little more to prevent popping fuses.
the bolt pictured is a ls1 coil or coil cover bracket bolt avail just about every where.
we also use them for bulkhead fittings.
Thanks for clearing that up. I wasnt sure exactly where it came from, just found a few in a box of bolts.
What terminal are you using? Is it crimped on? I would solder it on. A lose connection gets hot.
Edited by superben
that would be perfect. I am going to machine up something similar.
just checked all wires are neat clean not exposed.. the power wire has a connector soldered to it which then bolts to battery terminal.. each relay has a 10a fuse in.. should this be bigger or should i find another power source.. if pumps were drawing to much power wouldn't the 10a fuse blow? its only the power wire off battery rest are fine..
if someone knows more tech stuff about this pls pm so i don't take over thread thanks
Edited by Reese69
10a definitely isn't big enough. The pumps draw 14a, that will blow the fuse in just normal operating conditions. 15a minimum, preferably 20a.
thats what i thought but i have not blown a fuse, only issue is where the wire connects to the battery it burnt off - not sure but looks like the wire hits the battery about an inch off the terminal thats where it has burnt off...
Ah Woah, Yeh that's wayyyy too small. I'd be using 12 gauge wire as a minimum to the pumps, and 8 gauge minimum to the battery. The stuff you're using is what I use to wire gauges that don't draw more than half an amp haha.
ive got the same e85 intank pump, few weeks ago after some spirited driving the car turned off, check the fuse and it melted the fuse and fuse holder,
ended up finding out my fuse holder was only rated to 20amps, so I put a new 30amp blade fuse holder and fuse and its been great ever since
these pumps suck a lot of juice !
Are you running all 3 pumps off this single wire? A 3mm for each would be ok.
No chance! Even just running that size wire from the relay down to the pump, at 70psi fuel pressure, one fuel pump will be drawing 16a. 3mm wire isn't gonna cut it. Then you definitely wouldn't want to be running that size from the battery to the relay, as Reese69 has discovered.
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
