Deca Accommodation - Fri 31 May & Sat 1 June 2013
Bec
 Share
 Share
    • I’ve just installed a Uniclutch sport into my R32. I’ve been blown away by it… it drives like a stock Toyota Corolla. It doesn’t make sense to me that a performance clutch can drive this well. I was about to pull the trigger on a Nismo Coppermix twin plate when I discovered the Uniclutch and decided to give that a shot instead. They’ve changed the game and I couldn’t be happier.    I was previously using an Extreme cushioned button clutch with lightened flywheel. I’m still using the same lightened flywheel with the Uniclutch.
    • Mmmm no, that's a white series 2 R33 GTS-t
    • Oh and.... "no bubble on the dash" ---> immediate no mod status.
    • To be Frank (always liked that name), I reckon this is a better idea. I'm an R32 man from day 1 and the really good surviving examples that are still in stock form should stay that way. Let ye conscience guide you my son 🙂
    • Serious answer: The Japanese call them "HCR32純正アルミホイール" (HCR32 Junsei arumi wheel). https://www.google.com/search?sca_esv=9781a9b17bdb0a90&q=HCR32純正アルミホイール&uds=ADvngMi969x8VO53s3Ns6zY_q0mz1wQSG62T0CP-XYz351Bz4k-UlCLmEIs3_DOvTIrJbtR53zUINohMWufGSNcE7u-Sy3WX5TUjyDJHK7ocoDfeYw5W1tSwzUlYREw7kf4AsG4TMceIn7jdSxdsPXSr015SPQ0N4d0VoByGkenzSrAe8dyXSHA-cFV7LpaAVKCIPCKphRBK4ExnPj5Wp8Ymbl6ZrzN4uV9O1oqNcySxxJLogfY6FULbGlMPmheHkf5T89XXkWHUmA-Kn76muIhfC4LNQ0WaaP4QrndS6u2ovf8NUIsYJ7oFJ81Is4MDHNu_WMQr5vRcNCw-OO7NiSgP3rP02XVontjydtRrPYYnhoyPrwFoPHU&udm=2&prmd=isvnmbtz&sa=X&ved=2ahUKEwjYlNzYxcuGAxW72DQHHb8ODIAQtKgLegQIDhAB&biw=1920&bih=911&dpr=1 The English name for them would be "(insert model name) genuine wheels"?  As a side note, they fit perfectly on 1st and 2nd gen Suzuki Swift Sports: https://www.google.com/search?q=HCR32純正アルミホイール+スズキスイフト&sca_esv=9781a9b17bdb0a90&udm=2&biw=1920&bih=911&ei=aBBkZsT2KMS60-kP8IGZwAE&ved=0ahUKEwjEyoTbxcuGAxVE3TQHHfBABhgQ4dUDCBA&uact=5&oq=HCR32純正アルミホイール+スズキスイフト&gs_lp=Egxnd3Mtd2l6LXNlcnAiNkhDUjMy57SU5q2j44Ki44Or44Of44Ob44Kk44O844OrIOOCueOCuuOCreOCueOCpOODleODiEjCXFCgA1iiWHALeACQAQCYAYkBoAHzDaoBBDE4LjK4AQPIAQD4AQGYAgCgAgCYAwCIBgGSBwCgB_wH&sclient=gws-wiz-serp
