Been experiencing some blow bye on both my babies lately (33 &34), I suspect its because I have raised the boost and I do have catch cans on the way but can anyone tell me, technically (but not too technically), why this is happening ?
Also is there any way I can get the oil out of the FMIC etc ?
Jeremy
https://www.sau.com.au/forums/topic/42378-oil-blow-bye-cause/
First sign of piston rings/pistons starting to fail or getting worn.
Can quickly deteroiate to oil mist mixing with the incoming fuel charge which degrades the octane rating causing detonation and definate piston ring/piston failure followed by hammered big ends and bent cranks.
High hp/boost on a less than perfect GTR engine can very quickly end in tears...
Pushing the boost limits /timing on stock engines without CAREFULLY monitoring knock is very risky.
have seen more than enough atm in both RB25 and RB26...
Cheers
Ken
Ken
sounds like you just described how I abused my old motor to a tee:
* Strap on a pair of big terbs onto a tired motor with low compression.
* Wind up the boost to compensate for low compression.
* Periodically drain the oil from the dual purpose induction air heat exchanger/oil catch vessel (aka intercooler).
* Ignore intermittent knock warning on the PFC 'cause your half way through opening a can of "woop ass" for some knuckle dragger who thinks his new Genie headers make him unbeatable.
* Continue to ignore the dull wop-wop thud that happens at a characteristic 3,000 rpm.
Bloody amazing that I only cracked a crank and spun a bearing or two. Tough things them RBs, all things considered!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
