Hey Everyone.
Up for sale is my full exhaust off my 34GTR.
Reason for sale is I changed my exhaust to a nismo ne-1.
TRIAL TITANIUM CAT BACK - $2000
80mm (3.15'') / 115mm tip
Only done 4000kms with the rear muffler on and 500kms with the mid pipe on.
I purchased this through import monster at the end of last year for $2135 ( $2750 including shipping )
Asking $2000 on the basis of ive already paid shipping and its only been on the car for a very short time
http://www.trial.co.jp/osaka/original/bazooka/muffler.html
link to the trial website
CUSTOM MID PIPE - $400
76mm ( 3'' )
Only done around 3000k with this mid setion.
full stainless steel and cost me $600
this mid section pipe was custom made by BEST MUFFLERS in Carlton Sydney.
it has a magnaflow muffler, this mid pipe was made to substitute the titanium mid section due to it being to loud for my liking.
Asking $400 as again its only been on the car a short time and goes with the titanium exhaust.
VENOM CAT - $150
3'' flange / 4'' body - full stainless steel
Purchased for $250
Asking $150 as again only been on the car for 4000kms
TRUST GREDDY FRONT PIPE.- $350
2x 70mm - 80mm
biggest front pipes out there unless you get custom made ones.
purchased from RHDJAPAN at the end of last year for $446 delivered.
asking $350 as again only been on the car for 4000kms
Not in a rush to sell these but thought id get them up on here.
with everything the car made 324kw so can flow power.
I can sell these separately or all together. can ship at buyers expense.
can meet at the end of the freeway for Sydney people
PM or call/txt anytime 0409076032
Cheers Kane
Edited by kaneryan
https://www.sau.com.au/forums/topic/423988-r34-gtr-exhaust/
  • 2 months later...
  • 3 months later...
  • 1 month later...
  • 1 month later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
