Have we mentioned Adam = Telstra? Telstra is never cheaper.
yes telstra owned but still adam controlled for another 2-3 years. just like alot of parent companies that own smaller companies but if they are working well leave them as they were.
I have had my naked adsl service with Adam and don't have any issues with them. At the time of me getting my service they had the better deal to suit my needs than Internode, so it all depends on which ISP suits your needs better.
Well, just had a nice lengthy call to them both and Adam is a pretty clear winner =)
A bit cheaper, more helpful on the phone, and an all round better feel.
Now I just need to find the best place to buy a Galaxy s4 unlocked.
Asked about being telstra owned, and was told that they have not yet been bought out, and they might be becoming a parent company, so nothing will change.
So i think they will still be using optus mobile even if actually owned by telstra..
Look at the new HTC's coming out as well mate. According to some they are better than the S4. You can always buy the phones directly unlocked and just use whatever sim you want :D
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
