That's fine mate :)
Below is a list of all confirmed payments so far. If you feel I have missed you please send me a PM and I'll look into it ASAP!
Zeke
Lowbro
Smity42
Phillip Sutcliffe
SilverECR33
Sneaky Pete x2
Toddls
Clinton Cross
OMR31
AusieMark
Sneki81 x2
Sho Pi
Mum Slayer
Cadmoon
Kennysw82
GregR31
Grae35
Will depend on what Willowbank does. If it gets bad enough that THEY cancel the event it would be either refunded or rescheduled at their discretion. If it's just that YOU don't want to risk it, you pays your money and you take your chances. Same thing happened with the sprint day we ran, they were happy to keep the track open and people continued to run. Some people chose not to go out but as the event was still on that was their choice not to participate.
That said, BOM is predicting a fine day with a small possibility of rain with no more than 1mm of precipitation. Expect a cool, clear day with moderate cloud cover :)
That's fine mate :)
Zeke
Lowbro
Smity42
Phillip Sutcliffe
SilverECR33
Sneaky Pete x2
Toddls
Clinton Cross
OMR31
AusieMark
Sneki81 x2
Sho Pi
Mum Slayer
Cadmoon
Kennysw82
GregR31
Grae35
Bozman, we have Sean@EFI asking for 3 spots, & Supra Club; Tara Johnston, Sammy Tilbury & Matt Eacott
i made payment again because the last one got returned for some reason saying incorrect account even though i just entered the exact same details again from the first page, but i will definitely be there to.
Payment made, reference: 4343 (as my retarded local westpac can't put letters in their reference for some unknown reason :rant: )
Also if anyone has a pair of 15" 4 stud wheels hit me up as I need it for drag slicks
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
