If your so worried about what's legal & what's not, excessive revs, speed, noise, loss of traction are all illigal, so why not buy a Honda instead?
Make sure it's an Auto Honda Jazz, then buy RAYS extended lug nuts and install bucket seats from a Type-R.. don't forget the tow hooks front and back.. real JDM look & feel.. restecpa
Haha with chrome tail lights and chrome vault 17's...?
Op, they will never make it illigal to sell mods, people will usually mod a car before they register it with CAMs etc. you can't relate it to gun / drug laws because their directly related to safety. A blow off valve is not.
I understand where you're coming from but there are heaps of laws and restrictions in place unrelated to "safety". Like age restrictions on purchasing scratchies and lottery tickets. Age restrictions for viewing movies and tv shows. You have to show ID just to purchase a SIM card, how is that related to safety?
That's a bit naive perhaps.
Scratchies and lottery tickets is gambling. Gambling is restricted to adults, so that children with young, immature, plastic brains do not learn bad habits and become problem gamblers. Same with adult content in movies and TV shows. ID to purchase a SIM card is to try to keep the population under control - it's a matter of being able to police the use of technology that can facilitate crime and terrorism. Sure, they probably go over the top, but the natural tendency of any democracy is to strangulate itself with laws and regulations designed to "protect" the populace from itself, even if they don't really need it.
The very last thing anyone should be doing is advocating restrictions on ANYTHING that doesn't already have it and doesn't need it. Performance modification parts, etc, definitely fall into that category.
You have to show I.D because say for example you make a death threat or bomb threat with the number/sim card, they can trace it back to you.
Similar to if you were a drug dealer, sending text msgs back and forth about you 5kg of cocaine you want to offload, they can track/follow you.
Not related to safety at all..
  • Like 1
You do relise that 000 calls can be made from a mobile without a simcard.
And if someone was desperate enough they could use someone else's simcard, its not hard ive lost two mobiles in my time. Or perhaps attempt to use someone else's ID. Again thats not hard considering people lose their wallet's alot.
I purely made this forum to get an understanding as to why something illegal on our streets was significantly available to anyone. Not just those who use it for track purposes. Regardless of weather its safe or unsafe is irrelevant because it still is illegal.
U do realise no one would be stupid enough to call 000 to make a bomb or death threat, which was the example Kane used. He's right not only can sims be used to track calls, texts and phone tapping, it can also be used as a GPS tracker. Many people have been convicted of murder, from the evidence of there phone signal being in the vicinity of the crime scene.
While i c u have a point, at the same time its a good thing its not made illegal because why would we want to make it harder on us. I've always wondered when the speed limit is 110 then why the hell do cars can reach 300km/h, when a $100 speed limiter is all that it would take to enforce that law. It's because cars that reach that speeds will seel more, they make more tax, more jobs at holdens etc and then more revenue from speeding over the limit.
Some things are kind of whack yes but it's a good thing we can stil buy go fast bits, so not actually sure why u brought this topic up , weather u wanted to mod you're own car with a BOV and timer or just spark a heated debate
Edited by discoPumpkin
Where did I mention calling triple zero? I could be referring to making a bomb threat at your local KFC... Any person with half a brain would call their phone company and block their SIM card yeah?
Why is Marijuana so readily available?
Why are guns so easy to buy?
Like I said, worst thread on SAU..
Are you 12?
I thought school had resumed??
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
