after selling the skyline, i have been driving my mini for a while, although it's very "head turning" :) (seriously!), the reliably is horrible.
then this car come up in the trading post.
i just paid the deposit and it should be mine end of this week :rant:
it's a 2002 S15 Spec S, GT version
with standard leather seat and a few chrome bit
and very low 18000km
modifications
3 inch turbo back exhaust(Exhaust Technology) with titanium end pipe
pod filter
Blitz electronic boost controller SBC-DC
Blitz Front Mount Intercooler
Xtreme Heavy Duty Clutch
Bosch Fuel Pump (GTR Hi-Flow)
Apexi turbo timer
Blitz Boost Gauge
it's pulling 180rwkw@ 1 bar
the same time i already got somethings sitting at my home
a set of 17' 5 zigen deep dish rims
Apexi SAFC
Apexi CAI box
can't wait to criuse with u guy soon!
P.S. the mini is for sale!
u can take it for 3k
it's a 1100cc
with union jack
sunroof
PM me if u are interest :D
https://www.sau.com.au/forums/topic/42502-my-new-ride/
i still stay in SAU, ppls in NS.com act a bit too young for me... :D
i always love skyline, IF i am an aussie i am sure i will build a RB30 instead of buying this car.
wait till next year when i finish my study and apply for PR, then i might sell this and start build something nice...
https://www.sau.com.au/forums/topic/42502-my-new-ride/#findComment-871248
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
