Carbon Fibre Or Fibre Glass Parts 180Sx,s15,r32,r33,r34,r35,evo
Longz : R34 GTR Nismo Side skirts , Rear pods , Canards, exhaust shroud cooling panel and rear diffuser, EVO side skirts, canards, rear exhaust shroud
haz_jaz : skirts/pods and CF Wing blade for R34 GTR
Terry_GT-R34 : EVO Skirt Add-ons , Radiator Cooling Panel, Rear Boot Spoiler Lip
jase_c : R34 Gtt radiator cooling panel
DeaN20 : R32 GTR radiator cooling panel
Charles89 : R34 GTT CF radiator cooling panel
Sinno: Evo rear diffuser and canards.
Some guy: 350z lip + skirts
joelsy777 : R33 hood bonnet lip.60mm Pillar gauge cover,B Pillar cover, Centre console arm rest
DJRIFT : Carbon mirror cover r34gtt, R34 weather shields r32 lh headlight
YE34OK: Carbon: wing blade, exhaust shroud, wind deflectors *UPDATED*
gtsttrk:R33 Bee R wing
Coldfusion : R32 headlight intake,R32 FRP eyelids
tomo : R34 GTT carbon cooling panel and FRP R34 GTR JUN High wing stands
OON80 : R34 GTT canards
Yeedogga : r33 cf boot
riseofbrutality : r34 gtt cooling panel
89CAL : R33 GTR OEM wing blade :wub:
If I reach my 'old age pension' before the order goes through Longz, is there a discount? :P
Anyway, I'm wondering what the (EVO 8) rear c/f diffuser looks like now & drop the rear spoiler lip!
Thoughts? Pics of diffuser?
Terry : I was hoping we can both get pensions together and chase young ones around Blue mountains :P
There's the voltex and varis rear diffuser david is getting one aswell they can look very nice , Just becareful of speed bumps ! lol
Josh080691 : About $100 cooling panel and double dash seems like they moulded it for LHD American veichles =\
Update : Have been in talk's with supplier organising the freight down.
sime1 : seems there only for the R33 GTR "top secret rear diffuser"
Will be starting to collect the initial money for the orders will require 90% or full payments
GROUP BUY COMMENCING WE HAVE ENOUGH PEOPLE !! ~ FOR ALL THOSE STILL THINKING JUMP ON NOW !
I will be in contact with everyone in regards to funds transfer and there details ,
If i have missed anyone or have not contacted you yet you can PM me also !
Michaeltj : , R34 gtr skirts , pods , cooling panel and CF wing blade
Thanks Dave.
Longz, I'll decline the rear diffuser...
So just the exhaust shroud will be the additional item thanks,
Tez
It's nice, but I just bought a new Nismo Front bar for the GTR Longz - so just the c/f exhaust shroud will suffice. Thanks for an update.
OYEAHA : I've sent a email to the supplier in regards to that question
Terry_GT-R34 : EVO Skirt Add-ons , Radiator Cooling Panel, c/f exhaust shroud
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
