Hi all
Recently I changed my brake pads with Endless Mx72 pads, machined disks,flushed fluid....
Brake peddal feels hard and its still not feeling normal since my engine build.(drive it once a week and have not test its limit yet)
Apparently only have 7psi boost and need to get a brake vacuum pump and res tank.
Just wanted to know what people using/doing to fix this issue?
thanks
https://www.sau.com.au/forums/topic/426147-brake-vacuum-pump/
I will have look the booster when i get the car back.Im not too sure about the brake place but he wasent too keen to test drive the brakes after he did it he said not enough vacuum .I had to bed the pads and it was struggling to stop.
talking to jim from CRD and he said he could fiddle with the cams to help the problem a bit.Or put a vacuum pump and canister ?????
I have done nothing to my brake system bar pads .would i have to do anything to master cylinder ?
my car is weekend car maybe 1-2 track day a year(havent been yet) so im not in to time attack or hot lap yet .surely there are people with extensive modification than my .what have you guys done to your brake systems.
Cheers
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
