Hi all
Recently I changed my brake pads with Endless Mx72 pads, machined disks,flushed fluid....
Brake peddal feels hard and its still not feeling normal since my engine build.(drive it once a week and have not test its limit yet)
Apparently only have 7psi boost and need to get a brake vacuum pump and res tank.
Just wanted to know what people using/doing to fix this issue?
thanks
https://www.sau.com.au/forums/topic/426147-brake-vacuum-pump/
I will have look the booster when i get the car back.Im not too sure about the brake place but he wasent too keen to test drive the brakes after he did it he said not enough vacuum .I had to bed the pads and it was struggling to stop.
talking to jim from CRD and he said he could fiddle with the cams to help the problem a bit.Or put a vacuum pump and canister ?????
I have done nothing to my brake system bar pads .would i have to do anything to master cylinder ?
my car is weekend car maybe 1-2 track day a year(havent been yet) so im not in to time attack or hot lap yet .surely there are people with extensive modification than my .what have you guys done to your brake systems.
Cheers
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
