yeah the n1 model works 100% with the s13 ECU. As long as you have the consut plug still on the loom you can simply plug it in and start playing.
Otherwise, if the plug isn't there, i can make one for you without the proper Consult connector (but a standard 5 pin plug) and some extra wire so you can tap it into the ECU wiring yourself.
Let me know how you prefer it.
Impakt
  • Replies 269
getting very interested and will most definetly purcahse one soon.
but, a couple of questions first.
have u found out if the blue backlit screen is feasible? and the total cost?
also, you have said there are provisions for 7 analogue inputs, what about the standard boost guage on the R33 gts-t. would it be possible to use it as an input?
Thx again,
Bill
Yep , got it two days ago. absolutely awesome mate. love it. have already run it through mine and me mates car and trying to figure out how to mount the bastard :)
  • 3 weeks later...
Are you sure that you wouldn't be able to make this unit display / clear fault codes?
I have a laptop and can do it via Conzult / Datascan, but I don't always have a laptop with me. Would be much easier via this wonderful unit...
yeah i can add the feature to view and clear fault codes, but i wont invest the time to do it unless the demand was there.
I'll add you to the (new) list of ppl who wuold buy one if this feature existed :D
I'll add you to the (new) list of ppl who wuold buy one if this feature existed :)
Thanks!
  • 1 month later...
  • 4 weeks later...
Update: I'm currently working on a Subaru (OBD-I) equivalent, and in the meantime thought i would add a fault code read/clear function to the Nissan one!
Price will still be the same and existing displays can be upgraded.
PM me if you're interested!!
Impakt
  • 2 months later...
Hi Impakt,
i bought one of these off you aaaages ago (like, a year and a half ;)) i was wondering if there are any software upgrades or anything like that that have changed over the years of you making them, or are they still the same as when you started?
Mate would you believe they are still the same? A bug is yet to be found ;)
I mentioned adding features to see if it would get demand going again but it didn't so for now any upgrades are on hold.
Lately i have been spending my spare time getting the SubDataScan going..
Impakt
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
