1995 Turbo 200SX Luxury Spec
Stock Standard
93,500kms
SR20DET
5spd
Luxury Options - Sunroof, Dual Airbags, Front Lip, Driving Lights, tweeters on a pillar
Burgundy
Cyclops Alarm (Glass Breakage, Shock sensor, window lift)
JVC CD Player
18" ROH Fury Mags (Black Chrome) 80% tread
Daikin Organic Clutch
Whiteline lowered springs
Whiteline Camber kit
RWC & 7 Months Reg
Immac inside and out
Serviced regualry with Redline oils
Looking at $17,500 ONO
http://photos.yahoo.com/marzwest2003
https://www.sau.com.au/forums/topic/42627-s14-200sx/
  • 3 weeks later...
