Hey guys, ive been having trouble getting the right bolt for the factory turbo lines.
Theres a thing that loops around the turbo into a sorta C shape, at each end being a banjo fitting to feed the turbo with coolant and water
so that the 2 fittings will sit next to each other for ease of removal.
now ive got the thread for the water feed and return correct whichis m14 x 1.5
but the oil feed line is being a bastard. M12 x 1.25 Banjo bolt with a restrictor for my -5 ball bearing turbos is what ive been told to run into the C Line thing that runs around the turbo.i have ordered 2 different brands of m12x1.25 and both dont fit...
it seems to me that they are too small for the thread, and act as if the thread in which they are going into is fked.
(continuously tightening to a point and then becoming loose again..)
BUT, i put the factory bolt back into the same hole and everything is tight and good all the way down the thread?
side by side comparison braided line fitting is slightly smaller than the factory piece. have asked them multiple times if its the right piece aswell...
tried stepping up to the m14x1.25 and thats too big >.< wtf?
So if all comes to an end ill probably end up reusing the factory oil lines, which means front turbo out again.....
weld the end of the banjo and drill a 2 mm hole to act as a restrictor.
Anyone ever bored out a banjo piece to suit a slightly larger bolt? (<1mm opened up)
Maybe the banjo piece needs a bit of heat to expand and seal?
Thanks guys
https://www.sau.com.au/forums/topic/426424-no-banjo-bolts-fit/
Thread matching is not that simple.
I found Enzed/filter facory had no matching bits in their catalogue for mine, i had the banjo modified. You may have to do this.
Try a different brand of fitting. Threads are machined to different tightness, sometimes they dont really go together.
If you think there is enough engagement to hold it solid, use teflon tape to seal it.
yes i think you may have had the same problem as me?
the thread size goes in very well but doesnt fit...?
did you just grind out the edges of your new banjo to accomadate the larger factory turbo oil bolt?
im not sure if this is safe to do or not =/
teflon tape will definately keep in tight :)
for some reason the rear turbo banjo bolt went in and stayed tight =/ its a bitch to get to though :(
I used original banjo fitting and bolt, modified the line.
Dont have original ones?
Try asking people for banjos off their old turbos; i have an old rb20 one they might be same as gtr.
Or get a good quality line kit; make sure its got all the bits, the expensive one usually do.
Edit: GTR? spend the dosh and get the good kit
Edited by D.I.Y. Mik
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
