Here are my tips:
1) use 2 jacks. that lets you change the angle of the gearbox as required
2) make sure the rear of the motor is as low as possible. ie the rear of the head should be resting on the firewall
3) it will not go on the right way around. you will always need to twist it so that the starter motor housing clears the body. Once it has cleared you twist it back around to straight
4) the gearbox angle and motor angle must match perfectly. this is the biggest tip!
5) if they are lined up properly and not popping in, you may need to rotate the gears a little. this is because the splines on the input shaft have to match the splines on the clutch. this bit is luck! If you need to turn the gears a little put it in a short gear and turn the tailshaft or rear wheels (assuming they are off the ground!)
6) the gearbox angle and motor angle must match. I know I already said that but it's important! as you get closer it gets much easier to judge by how the flywheel compares to the front of the bellhousing. If the gap is bigger at the top vs bottom or right vs left it is not straight enough.
7) because of the spline alignment luck (#5) it generally goes in with a little clunk. When you hear that you have won!
8) once the box is within 2-5cm you can help it in using a big g clamp or 2 between the block and bellhousing. Once you are that close the input shaft is lined up OK and it is just the final adjustments. Never never force the box when the gap is large because you can bend the gearbox input shaft, which f**ks it.
good luck!
  • Like 1
https://www.sau.com.au/forums/topic/426576-flywheel/page/2/#findComment-6889374
is there a trick to getting the gear box on? or do we just need to keep trying to twist and push = feels close but just wont go in anyfurther
Most likely the clutch isn't aligned. I have a clutch aligning tool.
Also my tip for reinstalling the gearbox is leaning the engine back. You can loosing piping, exhaust and lean it back with a strap from a solid mounting point.
https://www.sau.com.au/forums/topic/426576-flywheel/page/2/#findComment-6889612
fly wheel was bolted up clutch plate was put on while the aligning tool was on and holding it then then cover plated was bolted on - then the tool was removed - i also put it in and out to make sure was ok and was fine..
thanks duncan will be giving this a good crack tonight thanks
https://www.sau.com.au/forums/topic/426576-flywheel/page/2/#findComment-6889830
I did it all on my lonesome..... not easy.
Try grinding off some of the rib over the starter motor, you will notice this bit is in the way just before it goes in, or you can bash the trans tunnel with a mallet.
I thought my clutch was mis aligned, but no, it was the thrust bearing had slipped and was catching on the shaft.
Now you see. NOW YOU SEE! (red dragon)
https://www.sau.com.au/forums/topic/426576-flywheel/page/2/#findComment-6890005
yeah that was a proble we where having it was fouling on something - strugling to rotate the gear box and manover it in -
but duncan has given a few tips we will be trying tonight
nothing has been simple with this car
https://www.sau.com.au/forums/topic/426576-flywheel/page/2/#findComment-6890077
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
