hi there, i have a "00 rsfour stagea with the rb25NEO and i am trying to figure out wether i've blown my piston rings or turbo.
i've searched but havent been able to find anything about this so if theres a thread about this please just send me a link or tell me where to look.
now, i was driving along the freeway at around 130km/h and doing a few pulls and playing around with the gears and spooling the turbo up as it's my first turbo car and had only driven it from where i bought it so far. as i pulled of the freeway and stopped at an intersection without any warning the car just starts blowing smoke and ran rough as anything and just felt like it was stalling and starting up again so i limped it downhill to a carpark and shut it off. when i started it i held the revs around 3,000rpm and it blew smoke like crazy but didnt feel like it was misfiring at all, but as soon as the revs dropped below 2,500rpm it would completely drop like it was stalling and starting again and i couldnt bring the revs back up.
i have the turbo off and just played around with it and there is a bit of play in the shaft and when i spin the the blades i can see oil coming down the blades from inside the turbo.
so i really need help with this before i fork out money for a turbo or rings.
any help is appreciated
https://www.sau.com.au/forums/topic/427036-rb25neo-blown-turbo/
you guys don't think if he did a seal in the turbo it would put the oil into the air and into the cylinders/plugs and it would smoke and run rough? My R33 did the smoke/run like a pig thing when my fuel pump shat itself and it leaned out and destroyed the ring lands on the pistons(amongst other things) but that was white smoke, what colour smoke was yours?
cheers guys for the other ideas, havent even looked at the cooler yet, but when i took the turbo out one of the cooler pipes had oil all around it. and my fuel was on empty pretty much so i could've done something to the pump
also it was blue smoke pouring out the exhaust
yea had the cooler pipe off for a while and cleaned it up when i did. but all through the cold side and into the throttle body there was a fair bit of oil so im hoping its the turbo, if it was seals the oil would be on the echaust side of the turbo and not through the intake? that make sense or am i just rambling like the rb noob i am? :P
Is there bucket loads of oil or just residue?
Your blowby vents back into the intake on stock cars and does cause the whole intake to look rather grubby over time.
If you were mopping a litlre of oil out of the cooler pipes i would plug up the oil feed and return to the turbo and do a comp test to make sure the engine is ok. If its only a whole stack of gunk stuck to the sides of the pipework i would put my cash on it being a turbo.
How wet is the turbine wheel of the turbo? is it soaked with oil?
turbine was clean but i also didnt get the turbo off for a few days but just spinning it in my hand i had oil coming down the blades. and it looks pretty gumky but not litres at all. it didnt drip out of the pipes or anything.
im gonna try get a new turbo first get that back together then do a comp test as im getting a bit lost with all the parts in my garage.
I would say you just blew a cooler hose off somewhere
Cause if the turbo blew an oil seal it wouldn't idle rough but just blow smoke and if the turbine wheel was dry wont be a turbo seal as oil won't dry up
And a light film of oil in the intake of the turbo is normal blow by
i think the smoke was caused by the turbo seal (just going with the general advice i've been getting). not saying your wrong by any means because im not really in a position to doubt anybody haha. comp test definately if it keeps smoking up im just really hoping it is the turbo
Come on guys really? It would never blow blue smoke unless there is OIL IN THE COMBUSTION CHAMBER........ A blown cooler pipe will NOT cause oil to pour into the cylinders, only a few things could cause the problem stated and judging by the description it sounds like a blown piston, however u start with the cheap stuff,
Pull out the plugs first, look at the condition of the plugs, if the are covered in oil it will confirm you have oil getting into the engine before the intake manifold, if only one or two plugs are covered n oil then it an internal issue localised to those cylinders. If you hav an exploded plug then its lookin bad for the motor, Next do a compression test, if all cylinders come up good its more likely to be turbo or valve stem seals, start with those simple checks then let us kno what results you get
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
