This is off my little brothers car.
Purchased new about 12 months ago but was removed a couple of months ago
due to an upgrade.
Turbo has done 12,000 klm
Low boost 12 Psi = 210 rw kw
High boost 18 Psi = 242 rw kw
Very responsive turbo with the power it makes.
Excellent street turbo with good drivability, much stronger mid range power then a stock turbo.
This has always been cooled down for 5 mins as he has a turbo timer and alarm intergrated into one.
He is overseas at the moment and asked me to pay his CC bill in exchange for the turbo. I dont have an GTST and both mates with small block RB's are going to be using bigger turbo's so its no use to me!
This is a complete set up
Turbo $1700
Twin Dump pipe $250 (can’t find the splitter attachment) (ON HOLD)
HKS upgraded adjustable actuator $300 (ON HOLD)
The turbo will be sold with the braided line kit, gravity drain, water line kit and 90 degree snout. All banjo's are supplied.
Also supplied is the HKS literature that comes with the items
I have a spare 90 deg snout that I was going mod but no need any more so if anyone needs it $70
Check out the pic’s for condition!
Located in Sydney but can ship interstate at reasonal prices and excellent service.
Yes, parts will be sold seperatly and I have put the costs next to each item.
The turbo dump will fit in place of the factory dump pipe which will then bolt onto whatever front pipe you had on it, as long as it fit the original DP this will fit everything as it was.
Preference will be given to the person who buys the turbo for teh wg and dp.
if you or anyone is interested in the other parts other then the turbo, please PM me, first come first dress. When the turbo is sold and they make a decision of the accessories you wil be notified ;-)
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
