Hi guys,
i run a search on this but found nothing so hence the birth of this thread.
Any of you guys using/hear/experience with YMS ECU chips for 32 GTR before?
I did some research on it and found quite a far bit of ppl using it in Japan and the US.
Just wanna see if its used here as well.
thanks all in advance :rofl:
https://www.sau.com.au/forums/topic/42770-yms-ecu-for-32-gtr/
If it is anything like a standard ecu rom chip then there isn't much point.  Better value for money is to spend on powerfc or other programmable ecu(s) where you can tune for the specific engine/condition.
i see your point, Will. Just that i'm after a GTR with a YMS chip and would like to find out more about it.
i got few friends in japan,they told me YMS are very famous in japan for refresh GTR and their ecu tuning are very good too,its very similar like mines ecu,
yes Jones but still, tuning can be a probably becos the car is here and not in Japan. I know that C&C can tune it but still, i will like to know its capacity and stuffs™.
who is jones??also you can check in the GTR magazine,its hows a lot of ppl use them in japan and also u can check the yms web site to find out more abt this ecu,hop that wil help u??
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
